Thread: ABS pump and solenoid relay Q
Created on: 06/06/18 06:20 AM
Barbarozza63
Barbarozza63's Gravatar
06/06/18 6:20 AM
Hi guys
Norwegian (old) man here, my first post. hello to everyone, need some advice
Have a late 2007 first gen with ABS europe model and I change my tires last weekend, I do all my maintainace my self, and been lurking this forum for the last 5 years for tips and tricks
Well, I put on some brand new fresh Michelin Road 5 (stock size) and after that my ABS light came on.
I tought it was the wheel sensors or the speed sensor ring since I changed my tires my self.
But I was wrong, they look good, the rings are in mint conditions and after testing and controlling the ABS I got the code 19 fail, ABS Solenoid relay failure. 1 + 9 flashes on the ABS lamp.
I reset the ABS, took it for a short drive but still the same. Reset again, took out the battery, checked the tires again, checked the pressure and everything else I could think of...since I find it strange that this happend just on the same time I changed my tires. But I do not got any sensor fails...still code 19
My question is, is this Solenoid relay a part of the ABS pump under the tank or is this a single part ? And if....where is it located. No big deal, I can use the bike, but it is annoying me :)
Anyone knows ? Thanks in advance
Oyvind
Norway
* Last updated by: Barbarozza63 on 6/6/2018 @ 6:21 AM *
RE: ABS pump and solenoid relay Q
06/06/18 6:54 AM
Welcome...but ABS on a 2007?Hmmm...zx14?Can't find that anywhere.My info finds a 2011 as having ABS.
* Last updated by: Grn14 on 6/6/2018 @ 6:55 AM *
06/06/18 7:10 AM
The US ABS came in 2013 and on. From the 2013 ABS wire diagram ABS is not listed as a function in the relay box. That implies the ABS relay could be in the ABS Hydraulics module. This diagram also shows a ABS self diagnosis system connector and a ABS self diagnostic terminal so a dealer with the correct software should be able to tell you more details.
A Gen 1 wire diagram should list your functions and connections.
Barbarozza63
06/06/18 8:23 AM
Thanks guys
I have the wirediagram, but it is not easy to see if this is a part of the ABS pump or not :-)
But I guess you are right Cruderudy
Yes in Europe most of the zx14 or ZZR1400 as we call them here have ABS.
I will try to do some more testing with my multitester and the diagnosis system to find whats wrong.
I keep you updated. It might be a ghost of something :)
* Last updated by: Barbarozza63 on 6/6/2018 @ 8:24 AM *
06/06/18 11:05 PM
hope you get that sorted out soon, Barabarozza.
Barbarozza63
06/07/18 1:33 PM
Thank you Rook.
Not sorted, but good news
Code 19 was a ghost, triggered by the control of the fuse , and the system remember the lost signal. After 140 km at work today I got the 4x4 flashes and that is tve rear sensor. Much better and a easy fix. I guess I must have toasted the sensor my self...hmm but a sensor is cheaper then a abs pump. And by the way, the solenoid relay is a part of the pump, stated in the 2012 + service manual. But not in the 2006+ .
06/07/18 1:35 PM
